S8+ camera has weird circular noise
sssharan
i see these purple circles in all my pics .. even the ones taken in daylight- if a pic has a dark area there are these purple circles.
is this something to do with the settings or is the cam faulty ?
oh this is the RAW image opened in photoshop and saved as a JPEG .. the saved jpg does not show this.
Check to see if there is a protective film on the lense you haven't removed or I'd ask where you bought it about a warrenty exchange. Could be a camera defect.
got it from best buy .. no film on the lens .
the weird part is that this is seen on the raw images only and not the jpegs.
looks like it gets fixed somewhere in between
I would try clearing the cache for the camera app, could be a software glitch.
daniey
