I wonder if a factory reset would help. I know it's kind of a pain, but it might help.And this is after I wipe the cache partition and reboot it several times
none of my notifications and ringtones work since beta 3 :/
None of my ringtones are working with beta 3
Same happened here.
The solution is to go in and trigger notifications off, then back on again.
For the ringtone, change it to something else, save it, then set it back.
The clue to me was in my custom ringtones: in the contact entry itself, under ringtone, it showed a 4 digit meaningless number instead of a ringtone name. I changed it to the actual ringtone, and all was well.
So you have to trigger all the sounds to make them happen again.
New hotfix (ZRLA) for Beta3 should be coming around soon. Fixes the appearance of notifications in Night Mode and issues with ringtones. Yay.
Was available yesterday in the South Korea.
Still no Beta3 hotfix...might as well wait for Beta 4 as that's due sometime next week if Samsung sticks with their bi-weekly update schedule.
