sjaduae
No I think they are all using the new gear S watch styler app which has all the instruction included.
You can DL this to your phone now and make your own creations by making a jpg background and storing it in your phone gallery so the app can use it, then add your hands, dates, app shortcuts etc anywhere on your created background from the styler app
Tip: To add more shortcuts but they are cluttering the screen you can place them say over the dial numbers eg V and make them 100% transparent in the settings, I have 3 each hidden under the V VII and XII. This saves having to make an app bar area which makes your watch face smaller
You can then put them on your watch using the new Samsung gear manager or export the them to others in a OWSC file format
BTW to post a screenshot of your dial by holding the home button and swipe left to right at the same time
