Hi! Anyone out there have plenty of experience with using the Gear S with the different connection modes? I have just purchased a used Gear S (because I am with Sprint and they are not carrying them and no one -not even Samsung could find one for me). It should be here today, so I'm trying to figure out all of the specifics. No one that I talked to at Sprint seemed to know much at all and I got conflicting answers, so I'm confused! I did make sure I purchased a barely used (someone switched to Apple) Sprint version.
I currently have a Gear 2 and I LOVE it, BUT, I was annoyed when trying to go for a run or something that I had to carry my Galaxy Note with me (which is no small phone) for it to work. I don't always have a pocket. Also, sometimes when I leave my phone upstairs, or even just go to the back room to the dryer, it disconnects because it's too far (or if I leave my phone just to run into the cleaners). Sooo, I was seriously Jonesing for the Gear S so I could just leave it connected at all times and not have to worry about how far away my phone was.
Well, with some research, if I'm understanding things right, I'm not so sure that the Gear S is going to help me out that much (except maybe in the case of a short run). It seems that the problem might be the tiny amount of data and limited minutes that I will get with the Sprint Gear data plan. It would be amazing to just leave it connected via the network all of the time so I didn't have to worry about going in and out. With my Gear 2, I just answer calls on it and don't worry about how many minutes I'm using or anything -I never worry about how many e-mails are coming in (I have several e-mail addresses and it's always going off between that and texts). But then there's the problem of it disconnecting so much when I move around.
So, Here are my questions....1) Is there any kind of work around so that it can be just connected all the time without using the gear data plan?
I know that there are 3 ways to use it (actually 4 if you count being able to foreword your smartphone calls to the gear). 2). I was told that if you connect via Bluetooth, you can use your mobile data plan (mine is unlimited) or your wi-fi just like with the gear 2 and it won't use the gear data. Is that correct?
3) What about texts and phone calls if you are connected via Bluetooth? is it still like the Gear 2? or will it use my allotment of texts and phone minutes on the gear plan (if they are texting my phone)?
4) Connecting through the network... Does this still allow e-mails, texts AND incoming phone calls from your mobile phone (and you can see and respond to them from the gear S?). If it will transfer your phone texts calls emails etc. -I'm assuming that this would use your text, voice and data allotments even though they are actually being sent to your mobile phone number??? *Edited to say that I did just find that there is an automatic feature -if I understand right, I can leave it on Bluetooth, but if I go out of range, the remote connect will pick up -so that solves my problem of roaming around the house and losing connectivity (after 60 seconds, I think). (but again, will I get calls? texts?
5) If the above is correct, has anyone tried leaving it connected all the time and seeing how much data it uses? I'd like to just have it connected all day, but I worry about how many e-mails come through. I probably get about 30-40 a day between 3 different e-mail addresses. I know you can set it to choose which things you want to see on the gear, but I do like to know when an important e-mail comes in.
6) Is it correct that forwarding only forewords calls, not texts?
I think that is all I can think of for now. I'd appreciate any help!
