1. TB-1599's Avatar
    I have a AT&T 3G Gear S2 and all of a sudden (the last week or so) my battery life as dropped a lot. I could go a day and a half almost two before it needs to be charged. Now after only 7 hours, I am getting a low battery warning and I have to switch to battery saving mode... As anybody else had a problem like this recently? I turned off heart rate tracking and all of the exercise notifications. Is there a way to check if any background apps are running so I can turn them off?
    07-26-2016 03:32 PM
  2. H3aTeRzz's Avatar
    Had the same issue...only thing that helped was to do a full reset of the watch.
    07-26-2016 04:28 PM
  3. TB-1599's Avatar
    Do you mean a full factory reset or a soft reset?
    07-26-2016 04:43 PM
  4. H3aTeRzz's Avatar
    Full factory reset.....but try a Soft/Light Reset first....might work for you.
    07-26-2016 04:48 PM
  5. optimummind's Avatar
    That happened to me once in a while. To fix it, I simply powered off the watch completely then turned it back on after a couple minutes. A reboot once in a while seems to be good for the watch.
    07-26-2016 07:12 PM
  6. TB-1599's Avatar
    Did a soft reset yesterday gave it a full charge. I took it off its cradle this morning at 6 A.M. here we are a little over 8 hours later and I am at 21% I may just to a full factory reset today....
    H3aTeRzz likes this.
    07-27-2016 04:21 PM
  7. Dr Flibble's Avatar
    Same problem since last week, I used to charge once every 3 days, I've lost at least a day of battery. My watch updated last week
    07-28-2016 04:44 PM
  8. TB-1599's Avatar
    Full factory reset seems to have worked. I did the reset wed night. By the time I got home form work after taking the watch off of the cradle it was just over 50% So it seems better now. Today after a full charge I am 5 hours into my day. I have switch out the watch face a few times. I have been using the music controls and I am at 78% so I think I am good to go. Thanks for the advise.
    07-29-2016 01:02 PM
  1. Process System not responding. Help?
    By AC Question in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 06-01-2018, 08:58 AM
  2. 'Unfortunately samsung Accessory Service has stopped.
    Last Post: 07-26-2016, 04:33 PM
  3. Replies: 0
    Last Post: 07-26-2016, 03:25 PM
  4. Process System not responding. Help?
    Last Post: 07-26-2016, 02:49 PM
  5. Rooted HTC Desire 610 won't let me get rid of system apps
    By guilovsh in forum HTC Desire 610
    Last Post: 07-26-2016, 01:51 PM
