Firmware Update Gear S3
BonJoviGurl
Active member
Aug 25, 2017
30
i got the update yesterday and now I can't really use my watch, the battery drain is aweful. Yesterday it was 100% and was down to 30% in an hour today I took it off charger at 100% and again an hour later 30% I wasn't wearing it I wanted to see how long it would last, then I put it back on charger, charger is red and still battery drain. The other thing I noticed is I can't have remotely connected without it being bluetooth, what happened there.
Cowboy8467
164
Have you tried doing a factory reset after upgrading?
jgreg02
244
Any ideas about when AT&T will get around to releasing their update? On BlackBerry items it comes close to never. Are they better with Samsung?
BonJoviGurl
Active member
Aug 25, 2017
30
I am going to try that I just hate haveing to set up everything again, I had to reverify my credit card in Samsung Pay yesterday so I'll have to do that. I also noticed it wasn't 3.0 I got so not even sure what update I got but it really messed things up.
andrewg13
190
After upgrade I seem to have to manually connect when it gets disconnected like due to distance. It used to automatically reconnect. Anyone else see this.
anon(463177)
107
Ya know... I think I'll just sit and watch this for awhile. Mine works fine and I don't want to screw it up. You folks go ahead and test everything out and I'll learn from you.
smoke skull
83
I updated mine yesterday and immediatly noticed huge battery drains. The apps didnt come online for updating until this morning for me. I also switched off the gps but i cant remember if it was enabled before the update or not.
So now the battery drain actually seems better than before the update.
After 5 hours running i have used 7% battery. My watch also only has less than 500mb of free space left.
Deke218
1,333
187
63
Battery life usually suffers for a day or two after a major update.
Come on T-Mobile, push the update!
Cowboy8467
164
I am assuming this is with AOD off?
daves221
524
my battery drain was massive the day of the update.. hang in there, it will adjust back. now I think my battery usage might be better than before but haven't measured it to confirm. I did an additional reboot or two of the watch on the first day in case that helped anything.
stormywaters
60
I have a Verizon LTE classic version that I purchased from a friend but I opted not to activate the mobile network service. Any idea of the impact on how my update will be handled without the carrier service?
RandyRoyalty
