I have a few different batteries for my rooted Epic 4G - the stock 1500mAh, the Seidio 3300mAh, and a purported 3500 mAh battery I picked up on eBay (which, while very good for the price, is probably closer to 2500 mAh).
Anyway, my Seidio 3300 mAh is my everyday battery, It works great and my phone (running SFR 1.2, Genocide 2) and it is calibrated, giving me accurate readings on the Seidio 3300 mAh all day.
Now, on occasion my Seidio battery gets low, and I have to swap out the battery with my eBay battery, which is an extended battery also and fits in the case nicely. In a real pinch, I swap out the Seidio 3300 mAh with my stock 1500 mAh.
So my question is this: since my phone is calibrated to the 3300 battery (my everyday battery which I use over 80% of the time), does swapping it out with the other batteries (of different strengths) now and then mess up the calibration?
Does the swapping with other batteries give me inaccurate reads on when using the Seidio?
And when I am using the lesser batteries, will I get inaccurate reads on those batteries, since the phone is calibrated to the 3300?
Or will Battery Stats learn and track each battery separately, giving me accurate reads no matter what battery I am using at any given time?
Thanks.
Thanks.
