The phone itself is really light compared to the evo. It does feel slightly plasticy but sturdy if that makes sense. It is just as thick as the evo. and if it is only going to be about 3 pieces of paper thicker when the epic is released then not a bad phone. The screen is beautiful. I have to say the colors are great. The movie Avatar is stunning to watch. The colors almost look like they are wet. Blacks are black like the screen is turned off and the colors stand out. In comparison to the evo screen size, it is a little smaller. The feel in the hand is perfect just the right size, not to big and not to small. I did go outside with it and put it under the sunlight and I have to say I was able to see my evo screen better than the super amoled.
That being said I was worried that the phone would feel cheap and it is not. It was one of my concerns if not the major concern of mine. It gets a passing grade by me for sure. The difference in screen size is the off putting part. If you think the .3 difference is not much it really is. This can be overlooked though by the color representation on the screen.
If you go with the evo or epic you can't loose. As it stands now if you like movies and gaming (until the FPS issue with the evo is resolved) go with the epic. Other than that which ever phone you choose your good. Even with a physical keyboard added it won' feel like there is one there if you compare it to the evo.
