1.1gb Ram in use??
NoLED is a great notifications app as well, been using it for years on a few different devices.
tap'n
Looks interesting and colourful! Will give that a go as well, along with Notifier Pro and Floating Notifications
... In the computer's case I don't worry about the RAM because it is plugged in so battery life is not an issue...
A process not running, just remaining static in RAM doesn't use processor power, that's why it doesn't consumed battery.
Android tries to hold processes in RAM, as many as possible, in case their apps are started again. That's saving processor power and therefore battery power.
Thanks for the valuable information, Adamsberg.
- - - Updated - - -
BTW, I have tried and tested many notification apps and have settled for Notify Me.
Thanks for all your assistance.
- - - Updated - - -
Sounds good, glad you could find a replacement :)
How much RAM does it use?
600MB of ram for locker pro? Is that one of those crappy GO apps? No wonder lmao.
On a side note though my max so far is 1.2GB, any higher would be odd for me unless I'm running a background benchmark.
Sent from my HTC One using Tapatalk
Haha. Yes, I was shocked to see that one app is consuming so much RAM.
I agree with you regarding max use of RAM. It was worrying me and I finally got app that consumes about 10% of what LockerPro did.
If you're really concerned about RAM, there are a few custom ROMs that are very light on it. The one I'm running (SlimBean 4.3) has gone as low as 350MB :D
Thanks! My phone is just over a month old and I'm a bit unsure about custom ROMs. As of now, the RAM looks fine.
Alright. I felt the same way and until I found this ROM (like the 4th i've used) I never really liked it. Now I don't think I could go back
Can you please provide me with a link and/or can you share some points as to why it's so good?
The biggest factor in making me choose it was the battery life. Not so much of actual use but in the idle time. I haven't used my phone much this week because I've been busy with school so I'm on the computer a lot, no need to use my phone to search for anything. Anyway, I'm on my 5th day without charging it (2 days and 12 hours of having it on, I turn my off at night) and I have 38% left with around 2H and 45M of screen time.
If you want a stock Android ROM you might as well get one that has little to no idle battery drain.
What carrier are you on?
That's impressive battery life! I wouldn't mind that!
I am based in Australia. I'm with Optus.
Mudasir
