- Feb 6, 2017
- 97,145
- 13,036
- 113
Oh wait, you don't have the McLarenMost likely it'll get Android 13.
No your goodI have the box (unopened and sealed) and on the back it says 1907. On OnePlus the sim free version was selected. Did I get the wrong device from them?
I'm a newbie to OnePlus phones and always wanted to try one.
No your good
I think the 1907 is originally the T-Mobile model (single SIM) that has been factory unlocked. You shouldn't have any problem using a card from a different carrier. You can even buy a double SIM tray and use it in that model.Confusing for me because I started Google searching and found that the 1905 is the US Variant (that I assume is the sim free model) as opposed to the 1907 that is the TMobile variant I received.
Do you have dual sim card tray then it's globalConfusing for me because I started Google searching and found that the 1905 is the US Variant (that I assume is the sim free model) as opposed to the 1907 that is the TMobile variant I received.
Yes, but it's possible that it comes with the international ROM already.So you have TMobile version if it's 1907
Not if it's single simYes, but it's possible that it comes with the international ROM already.
I think your version is sim unlock for north America , I would get the global with dual sim if you can return itThank you all for the response but I'll have to check on this next week. I actually am flying out for work and was planning to take this phone with me. Since I'm a bit unsure about the carrier reliability I'll be traveling with my other phone and will open this when I return! Will post a screenshot then!
Ok then, have a nice trip. Just a quick explanation of how OnePlus builds work. The two letters at the end (BA in my screenshot) mean:Thank you all for the response but I'll have to check on this next week. I actually am flying out for work and was planning to take this phone with me. Since I'm a bit unsure about the carrier reliability I'll be traveling with my other phone and will open this when I return! Will post a screenshot then!
