11 Beta-Missing sounds/ringtones, and my solution.
fwn
333
87
27
Generally, I've been quite pleased with the beta one. However, today, I tried to install a new sound to my ringtone. I went into sounds in system settings and it appears that many of the sounds are unavailable. I'm wondering if anyone can confirm this and if anyone knows of a workaround. I did submit a bug report to Google
Fixed. Apparently, when I installed the betta the associations to the sounds became confused. In system I reset all the app preferences and now the sounds of working again. Just another adventure in Android land
I updated your title that you found a solution, and that it might help others if they run into the same problem.
Angga Aliya
