2.1 Lite!!! Option 4
Hey, I think this ROM would be sweet if I could get it working right.
I flashed it from the .zip using ClockworkMod. It loads to the unlock screen & then gives this error:
"The process android.process.media has stopped unexpectedly. Please try again."
If I hold the power button I get the option to reboot, silent mode, vibration mode, airplane mode, & mobile network on/off.
EDIT: I also just got this"The application Google Partner Setup (process com.google.android.partnersetup) has stopped unexpectedly. Please Try again."
I'd try wiping everything again and reflashing.I do want to add that this rom is out of date.This is from the very first 2.1 released for the hero.
If wiping doesn't seem to get it going then i would say try this rom and see if it give you the same problem. http://forum.androidcentral.com/htc...-32-651-2-odex-a2sd-updated-11-23-2010-a.html
so does this work for a none sprint hero??? all i am finding anywere is for sprint and there is a few apps out there that i want but need to be rooted stupid security issues all over the place mostly i just want the screen shot app and also if i root my phone on my 2gb card will my 8gb card be normal??
When you root the phone it does not alter the sd card in any way. It is only used to transfer files to the phone.
The only way to take a screen shot of the phone with the Hero is through a rooted phone with an app or with the SDK package. I have not used to SDK to take a screenshot, but there is a how-to I believe done a while back by Androidcentral. Search for it on the site.
Reactions: beezy
Nope this is for sprint hero's. What carrier do you have that way we can help try to point you in the right direction for a rom?
Here's a quick "how to" with the sdk package.It's super easy.
Go to the tools folder of android sdk,
look for "ddms" double click it,that will open a command prompt just wait a big menu will pop up just plug the phone in click on the serial number it's the top line. Then just go to "Device" at the top,click it and choose screen capture it will open a little display that show exactly what you see on your phones screen.
nistor
