androidvirgin
- May 17, 2010
- 56
- 1
- 0
Sorry.. Do this instead. Apparently it's different on the EVO than the X:
- Turn the power off.
- Hold the Volume Down button
- Press and release the Power button
- You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
- Select Clear Storage by pressing the Volume Down button
- Now simply confirm your decision: Volume Up for YES and Volume Down for NO
I would 1) power cycle the device or 2) a hard reset. Sounds like an app is keeping the phone from sleeping.
I can disable mine...After upgrading to 2.2, I've discovered that its not possible to disable "Background data". This was useful in that it prevented all the apps from trying to sync, send and receive data in the background.
From my tests, turning this off / on / off did not help. Task manager shows that there are a whole host of apps that just keep running in the background. Even if you kill them, they keep restarting on the back side.
Also, Android Market will not run if "Background data" in "accounts & sync" is not enabled.
The downside to this is that, this "feature" is not going to improve battery life.
Seems that the upgrade to 2.2 wasn't worth it considering it really only helped to reduce some of the jerky screen refreshing when scrolling up/down.
Second Gmail account not synching. Potential (still verifying) solution (thanks Gekko):
1. Delete & re-add secondary Gmail account.
2. Clear cache of Gmail App in settings > applications.
3. Add Contacts and Calendar sync along with Gmail for secondary Gmail account even if you are just using Gmail account.
4. For both Gmail Accounts - in settings - uncheck "Notify once".
5. Power down and power back up.
Didn't work for me. When I deleted and reentered, there was no cache to clear because I had already tried that prior.
How about a fix for SiriusXM app? It is not working properly, it reloops every minute or so.
First post updated, with solutions to all reported problems (except the bluetooth dialer issue).
If one more person reports a problem that is using a task killer....![]()
@Cory Streater how do i fix the app killer problem?
I am on the "cannot see my apps in downloads on the android market." group.
