- Nov 24, 2013
- 990
- 3
- 18
no....if you answer on the gear it is routed through the gear unless you swap it to the headset with the menu option like in the video.....remember the gear assumes if you answer the phone call on it that you want to use it for the call. if you want the call on your headset why not look at the gear to see who is calling but then answer on the headset.....not sure why the gear should function any different than it does seems pretty clear cut and defined the way it is.
I guess I would prefer to swipe to answer or reject calls on the gear than to click on the headset, you know, the same way on the note 3, you just simply swipe. From the video, it seems there're extra steps needed in the gear thru the menu option. At any rate, I agree...clicking on the earpiece would be another option, although it seems swiping on the gear for me is more intuitive.
As for call waiting, do you just click the earpiece also, put the 1st call on hold, click to get the 2nd call, then click again to revert to 1st call?
And same for pausing music while on headset with an incoming call?
Thanks again in advance.
Sent from my SGH-T889 using AC Forums mobile app
