3G and WiFi Reconnect Issue
dcreed
180
15
I'm having a WiFi issue. Droid v1 with Android 2.2 (forced as OTA is a myth). Problem was happening with Android 2.1, too.
I live out in the country where Verizon's "people" don't seem to show up much. I get a 3G signal in some areas of my house, not in others...most of the house is in the "not" column, particularly my basement office.
Got a WiFi AP (WPA) in the office, signal pretty good everywhere in the house.
So, of course, setup with my Droid to remember this AP. Anytime I get the barest hint of a 3G signal, WiFi is disconnected, as I suspect is by design. That's fine. However, when the winds blow differently and 3G isn't available, my Droid doesn't automatically reconnect to WiFi. I need to either turn WiFi off and back on or use WiFi Analyzer and manually connect.
As mentioned, this happened before sidegrading to Android 2.2, so I don't think I can blame it on yogurt. Anyone got ideas of what I'm doing wrong?
I have a similar issue, but have the EVO. I am beginning to suspect my router (Linksys WRT54G) or the Airave. Do you have either of these devices?
Same router. Hmmm. It's setup to broadcast SSID, and the Droid sees it just fine...just needs a kick in the right direction sometimes.
