4.2 camera problem, please help !
aprs2k
sup guys, okay i know there a thread for this already but it seemed to died out..
i recently rooted my nexus with codename android 3.8.0 (4.1.2)
toro.
and i cant use my camera " unfortunately, gallery has stopped" pops up..
okay well i downloaded the 4.2camera.zip file went in to recovery deleted cache and dvcache , uploaded the zip, i tried setting the premissions to rw-r-r i believe thats
what its suppose to be set at. and i rebooted and still nothing.
I also deleted the gallery2.apk file. because they say that it could conflict.
the only thing i dont get how to do is to move the lib. files? ...
help me out please ! i miss my camera !
thanks.
Well if you really want the 4.2 Camera, you should probably try flashing to one of the 4.2 roms...I'm using Mmuzzy's 4.2 ROM that I flashed using Wug Fresh's Nexus Root toolkit, makes it very easy...
I think you're making things harder than they need to be. If I were in your position, I'd do just as pdub73 suggested. Perform a full wipe (data/cache/dalvik), flash a shiny new 4.2 ROM (I'm partial to AOKP myself), and enjoy all of the 4.2 core apps. I know there were plans for 4.2 and later builds of CNA, but I'm not sure what happened. All I can find is 4.1.1 as the latest, and I only see reference builds for the GSM GN and the SIII.
Very true!! I just got this phone and it was the easiest thing I've done rooting and flashing wise and the ROM runs like a champ!! I couldn't be happier.. You should do that my friend :)
Winnie
