4.3 Update Features
As of today I keep getting a msg. that Says "WiFi network is unstable". This just started at boot up today. Anyone else getting it?
The phone flashes the camera flash when getting an incoming call now.
Any way to turn it off?
There is a way to turn this off. It's somewhere in the settings. I can't think of it off the top of my head.
Yeah, I want to turn it off too. I found the setting, but it's already off.
The solution is to check the box, then uncheck it.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
Am I missing something? I keep reading about lockscreen widgets but can't find anything, even when I go into settings and lockscreen.
I've always had some apps set there that I can open from the lockscreen.
Are lockscreen widgets something different?
I did get that message last night shortly after updating my wifi signal level was jumping up and down, today it seems to be more stable and haven't seen the message again.
Maybe the new rom just needs some time to settle in.
Would you like to share where you found the setting?
Try going into accessibility and then scroll down to flash notification. If it's checked, uncheck it. If it's not checked, check it and then uncheck it. I know it sounds crazy, but it worked for me. Good luck!
Ahh. Accessibility. It was unchecked. Now to see if that works.
Thanks
Notification bar icons
I like being able to move the Notification bar icons around.
I started getting it yesterday when I downloaded the update also. I thought it was my home Wi-Fi being stupid
Has anyone come across a way to select an alphanumeric keyboard? I had one before but now I'm only getting the QWERTY :-(
Stock mail improvements, able to create rules, ability to move mail to gmail folders.
Quickly found out max number of recipients for filter is 29.
Lame
Are you sure that you didn't have a 3rd party keyboard app installed? I don't remember an option for 'alphanumeric' in the stock Samsung keyboard. I'm still on 4.1.2 (MF1) if you can tell me where to look.
noroldie
