- Dec 3, 2010
- 5,285
- 165
- 63
I finally found the article that talked about the "Self Discovery Mode" that is supposed to be sent out via an OTA update in June once Sprint activates their 4G LTE service.
"Sprint will be taking delivery of their GNex's from Samsung with LTE turned off. Don't worry, the LTE is still capable. It just will not be on by default like many Verizon devices. When you boot up your Sprint Galaxy Nexus it is going to go into 3G mode. You will then be able to toggle into WiFi, 3G or 4G LTE. This is largely because at launch, the Sprint 4G LTE network will not be mature enough to support a 4G LTE always-on connection. Sprint will likely have less than 200 LTE sites live nationwide when the GNex goes on sale.
It is anticipated that Sprint will offer sometime in June the ability for the Galaxy Nexus to go into LTE Self Discovery mode, where the device will be able to search for a LTE signal on it is own, and turn LTE off itself automatically if it cannot connect to LTE 1900. This would be a pretty desirable setting. Keeping a LTE signal when at all possible, but minimizing the battery drain of just leaving the LTE on all the time. This will be particularly important during the phase while Sprint is in the process of adding service in your area. Self discovery mode is likely to be added via an OTA."
Sounds like Sprint heard the complaints from the Verizon camp and did something about it.
I have not heard that this plan has changed so YAY for us.
Mav.
Mav.
