5.1.1
Wow, everything is so much faster! Faster than it previously did even before I put any apps on it A few things I noticed that just run better. Google keyboard swipe, bubble unlock, camera launch from home button. Pretty much everything is faster. Lag seems to be gone, knock on wood. Now I shouldn't miss those funny pictures when my dog is yawning
For those of you who updated AND use Package Disabler, did you export your 'disabled packages' first and then enable everything before the update?
(I'm even thinking of doing a factory reset after the update just to be doubly-sure)
Yes. Works seamlessly
I installed 5.1.1 on my AT&T GS6 Active today, and now cannot change the Services to on in the Accessibility settings? Light Flow asks me to turn on, but I cannot. I had one app that was on, so I turned it off now can't turn back on? My apps appear to be accessing notifications anyway though?
Anyone else have this?
Tried to install google text to speech
A factory reset is a must when ever you get a update. You'll notice the difference
It worked for me the second time. To download it again, I just manually set the time ahead a couple of days.
I have the same issue. Online said you have to have at least 6gb storage left so that the update can go through.
By the way, I can't download again and have to way for another 24 hours. How can you download it right away?
Besides the new security features and Samsung Pay are there any features with the upgrade that are really exciting?
Unfortunately the upgrade didn't fix the issues I am having with the activity key!
I have typically done this in the past, but have only had this phone for two weeks. Even after that short amount of time, it still made a difference.
Can anyone share the update ?
Guess unlocked phones aren't getting the update so
Great news. I just found a firmware and will upload it to my Dropbox in a few minutes. Will post a thread to anyone in need. Of course you will need to use Odin for that
I feel like the phone is much more smooth than before. All the animation and app switching etc. Not sure that's because of 5.1.1 update or the cache I cleared. Never clear cache for 3 months usage. I cleared out almost 3gb from cache.
I have been using the light Manager to manage my notifications and get different colored LEDs... But since the update I can't get any color LED except for blue... I also have a blue flashing notification light with no notification. Any ideas?
I completely agree here. Everything is faster, even down to the trail when I swipe using the Google Keyboard.
Seems quicker here too. Not sure if it's because of the upgrade or the factory reset I did after the upgrade.
andiox
