5.2" 1080p
Re: 5.2" 1080p
To some extent... That was also down scaling from 4k to 1080, so it's a natural conversion that's easier for the GPU to handle. If Sony went from 4K to QHD (or QHD to FHD), it'd be a waste of effort.
It's all a matter of GPU cycles... The physical screen needs to push those pixels no matter what resolution, so power usage there is the same.
Interesting... So perhaps others could do a 4k display running at fHD most of the time
Re: 5.2" 1080p
Well, it could be done. Only problem is that 4K displays that small are extremely expensive... And to do that would be like buying a LaFerrari and running on 4 cylinders most all the time.
But it's a smart solution. Sony is kind of thinking ahead since a 4K display is senseless on a phone.... Unless you plan on strapping it on a VR headset... THEN it pays off.
A QHD edge panel on the Note 7 is some $270.. I can't imagine what a 4K AMOLED version would run.
Re: 5.2" 1080p
$270 is what Samsung charges for the screen right? Not what it costs Samsung to manufacture.
Re: 5.2" 1080p
Right, but what difference does it make?
Though I did read that the margin in the screen isn't that high. The edge screens are fearfully expensive to manufacture. I think it was the burn rate... Screens they have to chuck.
Re: 5.2" 1080p
The s6 edge screen cost $24 more than the s6 screen. The Note 5 screen cost $72.50, which is less than the cost of the Note 4 screen. Putting that together, I would venture that the note 7 screen is around $100 bom.
True, bit I don't put much attention into the unit cost like that... R&D recoup costs aren't really taken into account in that number.
I wouldn't disagree with you there, only that the $270 replacement cost isn't a realistic estimation of the cost of the screen... Just like the $75 battery replacement cost doesn't accurately depict the cost of manufacturing and r&d on the battery, which is pretty minimal.
Re: 5.2" 1080p
A 1080p display on this size is enough. the QHD and UHD displays are for VR. But the hardver is more bothered with that resolutions. So I think if somebody do not use the smartphone for VR, the QHD and UHD displays are not required too much.
Re: 5.2" 1080p
I would agree... Fhd is perfectly fine on a 5.2" display so long as you don't use vr
dumpsterrentals102
