5.3 keeps turning mobile data on
It took a while to reproduce my 'auto data turn-on' issue, and then another long time to reproduce it with LogFox recording the logs at the time (thanks for that suggestion @IsHacker ). I've now got a log that seems to capture the issue but, not being at all familiar with the logging, I'm now struggling a bit to understand more about the cause from what I can see in the logs.
For comparison, when I manually/explicitly turn on mobile data (via the drop down menu mobile data widget), I see the following in the logs -
1739351892.887 10032 14832 14895 D DataUsageController: setMobileDataEnabled: enabled=true
1739351892.887 10032 14832 14895 D TelephonyManager: setDataEnabled: enabled=true
1739351892.903 radio 3471 3804 D QcDataStatusNotification Service: MultiSim onChange(): subId = 1
1739351892.903 radio 3471 3804 D QcDataStatusNotification Service: onChange():uri=content://settings/global/mobile_data1 authority=settings path=/global/mobile_data1 segments=[global, mobile_data1] uriLastSegment=mobile_data
1739351892.922 radio 3471 3804 D QcDataStatusNotification Service: handleMessage: Data Enable changed to 1 on slot = 0
and I see something similar (but not identical) in the big problem log capture -
1738430214.184 radio 3471 3471 D zsj : Phone.isCarrierLockDataRadioTech, first setDataEnabled(false), then setDataEnabled(true).
1738430214.184 radio 3471 3471 D TelephonyManager: setDataEnabled: enabled=false
1738430214.187 radio 3471 3471 D TelephonyManager: setDataEnabled: enabled=true
1738430214.192 1000 623 623 E SELinux : avc: denied { find } for pid=24997 uid=10173 name=tethering scontext=u:r:permissioncontroller_app:s0:c173,c256,c512,c768 tcontext=u:object_r:tethering_service:s0 tclass=service_manager permissive=0
1738430214.197 1002 32757 567 D a2dp_codec: A2DP_GetCodecType:
1738430214.197 1002 32757 567 I chatty : uid=1002(bluetooth) btu message loo identical 1 line
1738430214.203 radio 3471 3661 D QcDataStatusNotification Service: MultiSim onChange(): subId = 1
1738430214.203 radio 3471 3661 D QcDataStatusNotification Service: onChange():uri=content://settings/global/mobile_data1 authority=settings path=/global/mobile_data1 segments=[global, mobile_data1] uriLastSegment=mobile_data
1738430214.206 radio 3471 3661 D QcDataStatusNotification Service: handleMessage: Data Enable changed to 1 on slot = 0
Does anyone have any suggestions about what might be going on in relation to the '... radio ... zsj Phone.iCarrierLockDataRadioTech ... setDataEnabled(true)', how to interpret it, or where I could find more help and info about what it might be telling me?
Reactions: IsHacker
From the log, I can definitely see you have those evenwell apps installed, even though you said you didn't. I can see these evenwell apps in your log: PermissionController, DataUsageController, TelephonyManager (not sure if this one is evenwell).
I think DataUsageController is responsible for this. Disable it from settings > apps & notifications, since you can't find it through pm list packages. Then, give feedback if it still happens.
The only mention of 'permissioncontroller' in the pm list packages output is -
package:com.google.android.overlay.modules.permissioncontroller
... Doesn't this imply it's a fairly standard package/component of android?
DataUsageController is mentioned elsewhere and seems to be a standard android component: https://android.stackexchange.com/q...ponsible-for-capturing-mobile-wifi-data-usage
The same goes for TelephonyManager: https://www.w3schools.blog/telephonymanager-android
Also, none of these appear in the full listing of apps under settings > apps & notifications. Neither are do they appear in the 'list packages' adb listings, except for permissioncontroller, which appears as shown above.
What is it about these 3 systems/packages that makes you think their origin is evenwell and so should be disabled? I don't have any reason to doubt you but it would be nice to understand what is it about these 3 that raises a red flag for you.
There is mention that nokia have, for a while now, ended their use of evenwell apps (https://dontkillmyapp.com/nokia), which tallies with the fact that I have nothing in my 'list packages' that matches anything from -
The very first log entry I included above would seem to be the closest to the problem, which is -
As far as I can tell, this is a 'radio and phone-related information' log, at (D)ebug level, but ... is it from some system or package called 'zsj'? I can't find any mention of 'zsj' or the 'isCarrierLockDataRadioTech' function/event anywhere. Are the pair of identical numbers a process ID from which the log entry originates and therefore something that I might be able to gather a little more information?
From what I can tell from this earliest suspect log entry that pretty much says it's turning on mobile data -
I think the two numbers (3471 3471) are probably a process ID (PID) and by executing -
ps -A
I get -
USER PID PPID VSZ RSS WCHAN ADDR S NAME
radio 3471 920 16150904 63104 0 0 S com.android.phone
which looks to me like it's this 'com.android.phone' process that is quietly turning on my mobile data.
However, does anyone know where I might be best looking for help from someone who knows more about this 'com.android.phone' package and
ps -A
I get -
However, does anyone know where I might be best looking for help from someone who knows more about the internals of this 'com.android.phone' package and the Phone.isCarrierLockDataRadioTech log message that comes from this process?
opegamani
