6.0 Volume controls not disappearing.
Elias Schmid
Finally got marshmallow!
Just, there is this issue with the Volume controls not disappearing.
So far i have
-wiped the cache
-rebooted twice
-googled the problem
Still no dice.
Any suggestions?
Thx in advance.
No, but i'm considering it.
But I just thought if there is no need for it...
We're you part of the soak test? Because we have a discussion about that over there. It goes away after 20 seconds
I was not part of the soak test but have the same issue on the OTA update. Was it supposed to be fixed before the OTA was pushed out?
Apparently if you turn off all accessibility items it works as designed.
This is confirmed.
Just tried it. The only Accessibility feature I had on was Moto Voice. Turned it off and lowered the volume and the volume indicator disappeared after about 1 sec. Turned Moto Voice back on in the Accessibility menu and lowered the volume and it stayed on for about 10 seconds.
I have Tasker, AutoInput, and AutoVoice Google Now integration enabled in accessibility and have no issues. If I enable Moto Voice, the problem appears. Disabling Moto Voice makes the problem go away. My point is that you don't need to disable everything in accessibility to work around the issue.
I had another app requiring accessibility setting that caused using the volume buttons and the resulting volume slider to stay on screen forever until a screen press outside the control. Even happens in apps controlling different system volumes. This is just another of hundreds of android bugs google has no intention of fixing.
LG V30 6.0 Volume controls not disappearing.
This is confirmed.
This is absolutely TRUE,
Disable Accessibility options,
Restart your phone,
Problem Solve!
Thanks for the help!
boone
