6.16.215 ics update leak
So I ran thru the program without doing a proper extraction and now my phone is not being recognized as a USB device on my comp. any suggestions.?
I apologize for all the questions and stuff but in order to try and troubleshoot your issue, these are some important factors......:-)
I have a small netbook running windows xp. When it did the extract it was just the standard extract wizard. Now when i plug in phone on this comp, it says device malfunctioned and is not recognized as a usb device. tried following instructions on a comp at work and when I put into fastboot mode it just keeps saying "waiting for device"
If I were to do a FDR while running this leak, what would happen?
Sent from my DROID RAZR using Android Central Forums
You would erase all your apps and saved data, everything that you personally set up would be restored to stock. The leaked ROM u installed would still be there. A FDR will not delete the operating system.
Sent from my SCH-I535 using Tapatalk 2
Thanks
My INSTALL keeps aborting. reading: Error in /tmp/sideload/package.zip (status 7) installation aborted
CAN ANYONE HELP??????
Frustrated! Sorry to drag this thread back up.... I am trying to get back to the 211 from 215. I have unzipped the file after doing a FR and when I try to go back the computer just says waiting on device?? I would like to upgrade to JB, not looking very good??
Azle
Azle
You can upgrade to JB from .215 go here
http://www.droidrzr.com/index.php/t...xt912-jellybean-windows-mac-linux-all-in-one/
And make sure the Motorola drivers are installed.... and you have USB debugging enabled...
.... telekinectically tapped ....
Why not download JB SBF and install it that way. Do factory reset before upgrade though.
If you use the sbf with rsdlite a factory reset is not necessary.... it will wipe everything anyway
... telekinectically tapping, tenaciously traversing the terrain...
I must be Phone challenged!! I don't see it for the MAXX. also do you think I should even if I can find it??
Azle
Azle
If you are looking for the sbf files you can get them here
http://sbf.droid-developers.org/cdma_spyder/list.php
Or use the utility from the link I provided a few posts ago :)
BTW ... the maxx and the regular RAZR 912 are the same..... the same utility and sbf files are used....
And yes .... you should upgrade ;)
If there is anyone in the DFW area that will assit me on this i will purchase you a 12 pack of your favorite brew to do this for me. tired of not being able to geter done!
I'm not in DFW area but I will try to help you :) .... what issues are you having ?
HD tappin' .... hillbilly style!!
Everrytime i try to down load the utility it won't work don't know how to explain it sorry! About ready to accidently drop my phone.....
Frustration set in and I took it to the Verizone store they warrantied it and i received a new on Friday. Thank you for your assistance.
Azle
Iknownothin
