[6.25.11][ROM] Bamf GingerBolt Sense 3.0 STRIPPED!
What do you want most from this ROM?
  • Total voters
As you see by my tag name I am clueless... Rooted, running sense 2.1, gb 2.3.4, das bamf 2.1, kernal 2.6.35.13-imoseyon. Have no idea what that means, but thats what my phone says.. Here are the issues that I am having.. Random lockup and lag with the camera.. Also random reboot of phone itself or random lockup of phone just on stand by... Is there anything I can do to fix these issues? Dont see any updates in the ROM manager... Could this be a kernal issue? Any advise/help is greatly appreciated...
You might like this rom - gingeritis 3d - it's based on a different gingerbread build that is newer than the bamf 2.1 build, and it has fewer bugs.
link to the thread for it:
[ROM] [MikRoms] Gingeritis 3D v1.0 Beta VI [07-25-11] New Gingerbread Base!!
also, random reboots of the phone are usually caused by the radio - not sure which radio you have upgraded to, but the Official MR2 Radio has been solid for alot of people. direct download link for mr2 radio:
http://dl.dropbox.com/u/25213603/1.70 PG05IMG.zip
md5 for this radio: 97c195d733f61c6a699528747aff6892
and if you need instructions for checking md5 or flashing radios you can skim thru this
http://forums.androidcentral.com/th...7-guide-upgrade-gb-sense-rom-radio-froyo.html
Reactions: NotJustAPhone
Thanks... I think your right about the Rom.. Before I had the phone rooted, I had it updated to the MR2 radio and it worked fine.. Once I rooted and had DAS BAMF installed, my radio was also reinstalled with vMR2.5... Thought that might have been the problem with the camera and the lockup/reboot issues so reverted back to MR2 but that didnt help...I will try everything you suggested out... I hope that it fixes the issues.... Thanks again
Btw, just remembered bc it was a while ago - on bamf 2.1/older gb base, overclocking to 1.4 ghz in the toolkit or with set CPU will give you a "fix" for the camera issue
just a quick question and i might have missed the answer somewhere i am not getting mms messages from 2 people so far whats the deal with that
Hello all! Was a noob not too long ago. Wanted to throw in my 2 cents.
Used several roms (aosp) with my droid x until comfortable messing with recovery and such. Then I got tired of 3g and snatched up my new bolt!
First night I rooted then next afternoon I went ROM shopping.
Was a devout follower (as devout as you can be in a month or 2) of the cyanogenmod. Wanted to get rid of Sense asap because I heard what a resource and battery hog it was.
I must say I installed CM7 with mr2.5 radio and had no issues...unless you count boredom.
Finally researched Sense roms with debloating. Turns out BAMF is the poo.
Used gingeRsense for a couple days and messaging stopped down loading pix messages. As did Handcent. Went back to CM7 until I just found gingerbolt senseless 3.0 beta 10.
Been my daily for 3 days now with awesome battery life, speed and graphics.
Lock screen is pretty bad ass too.
Switched from Handcent to Pansi and it seems to be just as nice.
The only issue I have with any ROM I have tries is the myverizon app does not work....and as such neither does the NFL mobile app.
Thank you so much to all the devs who spent so much time developing these roms, sense and aosp alike. And also thank you so much to those of you who seem to be pros st this stuff and take the time to give advice and help to us noobs.
jhdsultan23
