60 watt charging
I got off work at 9:30 tonight and at 9:20 I was on 30%. I plugged it in and got up to 60 to 62% I forget and then I stayed in the break room for another 10 minutes and got up to 84 something like that.
Whew, @mustang 7757, glad I didn't make a mistake in ordering.
IIRC, I ordered from Bestbuy because it's slightly less expensive - by very little, like maybe $5.
Ahh.. not that much cheaper
I might do best buy in the future
Your woot charger?
Yes! It's OtterBox it's a dual 60 which does 30 and 30 if you're plugging in two things. I didn't want dual but at the time I didn't see 60 on Amazon and I didn't know really what to get. But to get two of these for $25 and it says 3.0 when super fast charging so yeah I love it. And I was just using the cable that came with a 45 watt Samsung charger. And it actually listed for about 50 or 60 on their website and I saw it was 28.99 now even though I got two for 2499. But I'm glad it does the super fast charging 3.0.
I just plugged in my Samsung 10,000 watt super fast charging thing to try and it only says super fast charging. But I also have this other external that I love my UNI I'm going to try it later but it's a 45 watt 10,000 small thing and it's so cute and it's got a little lanyard on it and that's your cable that comes apart.
To get super fast charging 3.0 the charger needs to have a PD 3.1or above rating. PD 3.0 will not super fast charge 3.0.
You are correct.
For the Samsung Galaxy S26 Ultra’s 60W Super Fast Charging 3.0, you need a charger supporting USB-C PD 3.1 or 3.0 with PPS (Programmable Power Supply), such as the official Samsung 60W Adapter EP-T6010. Third-party options like the Amazon Basics PD 3.1, Anker/UGREEN 65W+ GaN chargers, and JOYROOM 140W also work. A 3A or 5A USB-C cable is required.
Reactions: Rose4uKY
Omg! Have you guys seen the price of the S26 Ultra on Samsung.com now? They're now doubling the memory for free now! It's ~$300 lower than when I bought mine, which was during the Unpacked event, so it was as early an order as possible.
Sheesh, Samsung, you're certainly treating your true fans poorly!
This is treating their fanbase really poorly.
check the trade-ins
Reactions: kide#WN
I bought the anker nano 2 65 watt which is PD 3.1. Works great. Amazon also has a amazon brand 65 watt PD 3.1 for $24 as well
I swear I must be blind because I'm looking at that Anker one and it doesn't say it's PD 3.1. I could just be tired, as well lol
Well, you may see in my pic above that the Samsung 60-watt charger's box also doesn't state PD 3.1 either!
So strange that these companies think this type of box designs, which obfuscates critical technical details, are acceptable "good designs"!
Reactions: monsieurms
Yeah I noticed the same thing, I was getting prepared to have to return it, but figured I would try it and it worked fine.
The new samsung charger is pd 3.1 on the website. Don't know if it's on the box. I also bought the belkin charger as well which is pd 3.1. Yea sorry the anker one does not state 3.1 but is PPS. I bought both to try. The anker and belkin both do super fast 3.0 charging.
Here's the belkin one:
Here's the one I got. It shows "super fast charging 3.0" when plugged into the phone.
Reactions: vader4633
Ashok Dharshan
