64 GB micro sd card?
This worked SUPERBLY! I googled a few other solutions, but none were as simple as this one! Thanks for sharing!
Like others I have been messing about all afternoon with my Galaxy Note 10.1 (16GB) uk edition bought at Xmas, trying to get the 64 GB Sandisk Ultra to get 'mounted' Used the instructions above and low and behold I now have 59gb of storage. The card was formatted in FAT32. Haven't actually saved anything yet, but will update once I have. Thanks HeyBeerMan
I do not have Jelly bean but have note 10.1 with 16gb and 64gbp external SanDisk.
When I first put it in, it did not recognise it But then put it in my Sony Neo V phone to check the card was working returned to SGN10.1 and voila! no w
orries no problem ever since.
Will I have to format my 64gb using my samsung S2 ? or will it format on the 10.1 note ? as it seems to be different for each relay
I just put my new 64GB micro SD into my GNote 10.1 and it works fine. I had no problems.
Yes the 64gb works on galaxy note 10.1:-)
If you open this image you'll see the memory storage
GQOmBguU
I have a Note with a 32Gb SD card and almost every time I restart my device, it does not recognise the card anymore and want to reformat it.
If you install the recent update, you will then be able to install the 64 GB card.
Sent From My Samsung Galaxy Note 10.1 Tablet
hi..so you mean if i update my ICS old version..to the new ICS version..it can recognised my 64Gb sdhc/sdxc..without format sdcard? and my note 10.1 now is root..is it safe to update? my note 10.1 its from asia/indonesia
Hi all, I've bought a SanDisk MicroSDXC 64Gb, i've formatted it as exFAT and my NOTE 10.1 see it correctly.
But I cant move any app to SD.
I've used also APP2SD but also it doesn't see memory card.
If I open Archive Native App of Note 10.1 then I can see correcty SD card around 60gb.
How i can move apps to SD?
Thx all for support
Thx all for support
Need to be rooted in order to move apps to SD card.
Why do he or she have to root? My stuff moved to my SD card without root. Some apps did not move while others did.
Hi Preach2k i cant move any app to sd, and now i've SD formatted as FAT32!!! and now i've seen that i cant launch also supersu is it normal?
I do not know. I did not have to format my SD card. I put it in and my Gnote 10.1 recognized it. I downloaded the app transfer apps to sdcard and it worked. I did not root.
Lassi876
