6P case and holster?
  • Start date Start date
interesting, that is the one I referenced earlier. here is a quote from the description...
The belt clip can rotate 180 degrees to provide you with flexibility you would never imagine--why not build a changeable wardrobe for your phone?
Possible they have changed the design then.
Thank you for your response(s).
Yes I'm sure, I just spun it around 360. This is the one I have http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4875665
It's very well made, but since I wont have my phone until Monday I cant speak for the fit. I dont see where it would be a problem, and it's gotten pretty good reviews.
OK, as I suspected (as people on amazon have reported). The clip to get the phone out of the case would be on the bottom, when the buttons are up, when worn on the right side. For me thats a deal breaker.
I'm not sure what you mean by this.
With it on my right side I can spin the belt clip around and have the phone retaining clip at the top with the buttons pointing down, or am I missing something?
The only thing I don't think will work, is to put the button side of the case into the retaining clip of the holster.
And I would add that the description is wrong, the belt clip does rotate a full 360 degrees so they must have changed the design.
right, I dont want the buttons facing down, makes it too hard to use the buttons efficiently, and then the phone is 'backwards' when removing it with the right hand. same problem with the MOKO case.
Holsters for Nexus 6p
Suggestions for holsters for Nexus 6p (that allow a phone in its case, and preferably one that allows phone entry into the holster's vertical top, as opposed to horizonal entry)?
redmercer
