7 inch or 10.1 inch?
Thanks Thoots!! I went onto dolphin and did see the "user agent". I saw the options were android, iphone, or ipad....what does the Ipad do that it can have its own custom setting?
Well, my version (Version 9.1.0, recently installed) has the following options:
Android (default)
Desktop
iPhone
iPad
Custom
I generally DON'T want the mobile sites, so I have chosen "Desktop," and it works pretty well for me. Otherwise, I'm not sure what the Apple-centric choices get you....
If you don't have those options, check your version, and go get the latest Dolphin browser version.
Good luck!
I have both a 7 and 10 inch tab. I use the 7 a whole lot more. Much more comfortable to hold and use. It is lighter which helps for reading. I could never read on my 10 incher because it is just to big and heavy. We now mostly use the bigger tab to entertain or daughter on long car rides or flights.
I use the 7" way more than the iPad(passed it on to my wife), I really like the size and comfort of the tablet for gaming, social media and so forth while on the couch or recliner... as far as heavy browsing/searching I will use my laptop so not really an issue for me personally.
Sent from my GT-P3113 using Android Central Forums
I have an ASUS Transformer TF300T 10.1" tablet and it works great. However, after a while, I found that the 10.1" format although good, was taking-up lots of space. So I bought a Galaxy Tab 2 7" and added 32GB to it. I opted for the Tab 2 in place of the Nexus 7 simply because of the ability to add a uSD card. Granted, the Nexus 7 is faster but quite honestly, I don't notice the difference. This being said, the 7" format is great! I believe that I will like this tablet even though I have no technical issues with my TF300T. So for me, the 7" format suits me more than the 10.1" tablet. Will I sell my TF300T? Nope... at least for now ;-)
uobuob
