7 Pro Power Button is Wiggling
YankInDaSouth
2,238
3,093
113
Anyone else have a power button that's got some play in it? A Google search brought up a couple of results but nothing too overwhelming ... wondering if this is an isolated case and if I should see if Google will let me exchange it before I put my Whitestone screen in on this one.
https://www.reddit.com/r/GooglePixel/comments/y96tnp/loose_volume_power_buttons_wiggle/
https://piunikaweb.com/2022/10/27/google-pixel-7-and-7-pro-volume-button-reportedly-coming-off/
Sent from my Pixel 7 Pro using AC Forums mobile app
Mine's a little wobbly. Never really noticed (nor cared) since I have a case on all the time.
I never noticed if mine was loose or not but I woke up to check my phone and the button was gone. Luckily I am still covered under warranty until February. I have to bring into a store for them to not fix it
You use a Case?
About 50% of the time I use a case.
And it's not going to be as easy as I thought. They have to replace the whole back housing which takes at least a couple hours and no one has it in stock. I'll probably switch back to my S21 until I can get it fixed .
