7000 Mah Samsung Galaxy s3 battery for $31
Will this work with my otterbox defender I got the camo one which is my fav style so I really dont want. To change.
If not are there any other options besides Anker? Astro2 Dual USB Output 8400mAh High Capacity Portable Power Bank Backup External Battery Charger with built-in Flashlight for Smart phones, Android phones, PSP, GoPro; iPad mini, iPhone 5 (Lightning Cable not Provided); iPhone 4S; Samsung Gala
Usage light no games 4g web surf 19hrs with 3% left
4G lte web surf kill the batt with in 3.5 hrs have not measured heavy use yet
Got mine today. The case is very nice. If it works, and I suspect it will, this will be the bargain/gotta have S3 accessory of the year.
I had been neutral about removable batteries, but, not anymore! :-)
Blue 32gb Galaxy S3
The otterbox doesn't fit this battery unless you do some serious modding to the backplate of the case which isn't worth it.
TMO GS3 * NEXUS 7
Ext charger it is then saw some good ones last night. Stupid but could I run without a batt door?
- - - Updated - - -
Color me impressed!
Started the 12 hr charge yesterday at 7pm. Used the phone for a few hours on WiFi. Let it charge overnight in Airplane mode. Took it off the charger at 7 am, turned it off, then back on.
Went to work. No WiFi, Bluetooth or GPS. Screen at 100%. No charger.
Back home, WiFi on and took the battery screenshot.
Awesome!
Blue 32gb Galaxy S3
Pulled this off zerolemon's website -
Compatibility: All Samsung Galaxy S3 Phones
Battery :Length: 13.9cm / Width: 7.3cm / Thickness: 1.6cm
Availability: Out of Stock - Restock on April 25th 2013
Warranty: 180 Days Zero Lemon Guarantee
Thank you!
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Gee geeky, not even a "Hey, that's great, thanks for sharing, btw ...."?
Blue 32gb Galaxy S3
My battery is dying so quick now.
TMO GS3 * NEXUS 7
TMO GS3 * NEXUS 7
On one of my charge cycles, i found it died quickly, but that was because I switched to a launcher that needed alot of resources, and I was having a huge android system and Google services drain
Sent from my SPH-L710 running Liquid Smooth RC2 4.2.2 stable
What launcher are you talking about? I use nova launcher prime.
TMO GS3 * NEXUS 7
TMO GS3 * NEXUS 7
If your battery drops real quick just out of nowhere for no apparent reason I would reboot phone something is stuck
aimalee
