A question about bluetooth codec between android devices and JBL portable speaker.
  • Start date Start date
A
Android Central Question
Guys I have a question for you all. It will be very nice if you can answer me
Do you use android or iOS? (proceed if you're on android)
Do you own and use a JBL portable Bluetooth speaker frequently?
important part
If so can you connect your speaker to your phone, then go to the developer option ( there are many videos that will show you how to do that) scroll down and then reply to me your
-Bluetooth codec ( remember, JBL speaker only, I suggest SBC will be the one)
-Bluetooth audio sample rate ( i really need this one) 44.1 or 48 khz
-Bluetooth audio bits rate
Also if you are comfortable pls tell me the name of the android device that you are using .
Thank you.
@galatic Zoo
Thanks for answering me, unfortunately I need the JBL portable Bluetooth speakers.
I have also reposted this question using my account already.
I've deleted the duplicate. It is best to use your original thread, so that all answers will be consolidated, which will be easier for you to get helpful answers.
omertasociey
