A Way to Get Band 4 LTE back After 4.2.2 OTA
That is normal for your Hspa+ signal to be stronger especially since tmo just brought out lte so its in the early stages.
Sent from my Sprint Galaxy Nexus rockin 4.2.2 using Tapatalk 2
Trying to see if I have the correct band in my area for LTE on AT&T. Used these APN settings and am not able to get any data whatsoever. Do I need to have AT&T re-add an LTE data plan to my plan? I thought using a different APN would be good enough.
APN: pta
MMSC: http://mmsc.mobile.att.net
MMS: Proxy: proxy.mobile.att.net
MMS: Port: 80
MCC: 310
MNC: 410
APN Type: default,mms,supl
APN Protocol: IPv4/IPv6
APN Roaming Protocol: IPv4/IPv6
APN: pta
MMS: Port: 80
MCC: 310
MNC: 410
You realize that ATT only uses Band 4 LTE in very, very few niche markets, right? Generally speaking, the N4 will not work on ATT LTE, only Tmobile's LTE.
Yeah I think only about 2 or 3 markets att has band 4 lte if I'm not mistaken.
yes. And I want to see if my market is one of those
Nexus 4 AT&T LTE support in limited markets | BGR
"...Android Police notes that if you own a Nexus 4 and live in Phoenix, Raleigh, San Juan, Los Angeles, Las Vegas, Oklahoma City, Dallas, Chicago or Charlotte, you might want to see if you can pick up on AT&T?s LTE services, since the carrier owns the rights to AWS spectrum in those markets."
Worked for me, sorta
Here are the steps I took to install.
1) Flash .27 or .33 (I did .33) in a custom recovery from ConTejas's link above. And be sure to grab the .48 one too in case you want to roll back (up?) to the latest one.
2) Settings > More > Mobile Networks > Access Point Names > T-Mobile US > APN > fast.t-mobile.com > Menu > Save
3) Go to the dialer > *#*#4636#*#* > Phone Information > Set Preferred Network Type > LTE/GSM auto (PRL) > hit the back button until you are back the home screen
(Don't select LTE only or you won't be able to make calls or get text messages)
4) If you have TMO 4G in your area you'll see your signal drop and pick back up with a 4G indicator. Turn off Wifi if you can't see the indicator.
When you reboot, you gotta set the preferred network back up, the APN setting will stick though. I heard some place that you can make the network type stick with a build.prop tweak but I haven't looked into that yet.
After reading this I wonder if I was having problems because I didn't change any APN settings or because I kept trying to select LTE/CDMA rather than LTE/GSM. After a quick search I reached the conclusion that T-Mobile uses WCDMA and GSM.
I'm getting a lot more comfortable with the flashing and using adb so I'll be trying this again soon.
Thanks!
Thanks!
no problem
it took reading through a thread on XDA to get the apn part. I missed that the first time too.
I've realized that in at least the DC/Baltimore area "rolled out" doesn't mean that every TMO tower has LTE. At home and near my house i can find a few towers that have it but at work where I always get full HSPA+ because I literally site about 25 yards from the tower, I don't get any LTE. I'm guessing that tower isn't rocking LTE yet.
I gave up on it for now and rolled back to the current radio but in a few weeks, after they have a chance to polish things up, I'll give it another try. overall the experience still feels like a hack job, and that's fine, but to me, reliable service trumps what at least so far has only been a marginal speed increase over HSPA+. It's still damn cool that it's even possible though and i'm hoping that somehow they make it a legit LTE device. Doubt that'll happen but I can hope :)
Ok so I'm a noob. If I do this won't the entire phone be back to 4.2.1 or do the images contain a means to roll back the radio only?
The images contain a single img of the radio. If you pull the out and only push them then the system will remain at 4.2.2. If you push the whole image though, yes you'll be back to 4.2.1.
Do you have that particular link?
After flashing the radio is there another APN called fast.t-mobile.com?
Thanks.
Thank God last time I tried data still worked so I could rely on GrooVe IP and set up missed calls from my regular number to forward to it.
Thanks.
No, you have to add one, or edit the one there
Found it. Thanks! Don't know if I should do this though. I mean, I have seen as high as 22 MB with HSPA+ right now. I am curious though.
Here's a thought. When 5.0 rolls out will they go ahead an re-activate the LTE, or will they find a way to make sure you can't roll back to the .33 and .27 radio imgs with that update? Needless to say my N4 has been taken off of auto update.
I really don't think we'll see official support. I hope I'm wrong. I just don't think the hardware is there to make the experience optimal.
Haha even though I ALREADY knew it was gonna happen Google already stated that the n4 is turning into the n4g as in official late support on 4.2.2. N4 owners should get an update shortly.
Naw no April fools joke bro its real Google it.
HAHA the writer might was joking or IS HE??? Its not like lte dosnt work on it.
mohitsl
