accurate battery icon on ED01
Hmmm... I was going to just give it a try and the framework-res file is not there. There is a new one called twframework-res instead. It should be in the system/framework folder correct?
Which file did you use? The EC01 version? Did you insert the apk file manually with a file manager or use the zip?
I just tried the EC01 one too and it seems to be working fine. It looks slightly different than the EB01 version. I'm not sure which one I like better. Either one is awesome! Thank you Adrynalyn!
slm015
