Acmeinstaller problem
baci39
3
Touchpad starts downloading to install CM7 but then stops and reads" no cminstall dir found,nothing to install". I can see the cminstall folder, I have the proper files installed in the folder? I might add I had this installed before but lost it once I updated my webos. I am stumped as to why it cant find it? Any and all help would be greatly appreciated.....
I'd delete it and create a new version with new files, If you had it installed before maybe the original files and folder were modified during the last installation.
Reactions: baci39
tried that but it did the same thing again? I get the two penguins and files seem to be loading on the touchpad but then it just stops again?
I really don't know dude, are you trying it with the first alpha or the second ? My next choice would be to try installing the opposite alpha from the one you have been trying.
draikin1
