[ACS][ROM] Phoenix ROM 0.2 & EXT Data
Re: [ACS][ROM] PhoeniX ROM 0.2
WhenWhere Poenix 0.3 rom? anybody?
I'm still testing.. PhoeniX 0.2 worked for the majority of people, so I'm taking my time making everything about 0.3 work. Especially with the addition of the Boost Replenish.
I don't like double posting, but I did this to (hopefully) get the attention of Boost users. For you Boost people out there, what is the latest update? According to the Samsung open source page, there are two versions: EK03 and FB03. I currently have an EK03 dump for Boost, but I own the Sprint version.
It'd be nice for both of us if someone could let me know which is the latest firmware version so that when PhoeniX 0.3 is out you aren't nagged to death about a new update.
EDIT: From the picture on the Boost web page, it also appears that your stock launcher has he "ID" icon on the bottom right instead of the browser icon. I was under the impression that the ID icon was for "Sprint ID," not a multi-carrier thing. If someone could let me know if it's there as well as the firmware version I'd be pretty grateful. I know enough to replace it with the browser icon like all other GB devices have, I'm just too lazy to decompile the app if I don't really need too.. :P
Any ETA on phoeniX 0.3? Ill try an alpha/beat build if its available.
Sent from my SPH-M580 using Tapatalk
Yes it comes with id simply labled as id and the latest update is EK03.
Boost basically is Sprint and Sprint has been making the public aware of that in several ways including this crapware.
Firehak you can add me on GTalk or some other for of instant communication if you'd like in case you need anything with the BST version
Sent from my HTC Hero S
I don't have an ETA on 0.3 for three reasons. The first being that I'm trying to make this a release where everything works "out of the box" if you will. Second, I'm having installer issues right now, so I haven't tested it myself. And lastly, the addition of Boost Mobile. While not a huge difference, all I might possibly need is a single Boost user to test. I own the Sprint version, and dmrlook does as well, so it's pretty much covered. Thank you for the offer/interest though, it lets me know my work is appreciated ;)
Thank you for letting me know both, it seems I wasn't lucky and will have to decompile our launcher after all.. :P I'll pm you my gtalk address if you do want to get a hold of me, but I have no more questions at the moment and will probably go to bed after a little more work. I got a little distracted with a fun new game called "Blacklight: Retribution" today.... :p
I am all for you taking the time to make sure everything works from the get go:)
Mini update! I'm making what I hope is good progress in apk reverse engineering! Why? I still want to get rid of the stupid Sprint ID buttons from the launcher! ;) Though, I probably should be working on the installer script instead of modifying apps, shouldn't I?
Attached is a screenshot of some smali code for kicks and giggles, 'cause I've been staring it it and xml for a good hour or so today. :P I believe this is the action for clicking the ID button from the menu, not the Launcher icons.
MOAR UPDATES!
I just booted in 0.3 for the first time and it is extremely responsive and smooth ;) I have one installer mistake to figure out and boot animations are still giving me trouble (If it appears, it doesn't go away until a kill the system process through adb). Expect a release soon guys!
Reactions: knarf802
Fantastic! this entire endeavor is amazing and i hope to see more awesome coming the replenish's way! thanks firehak! also i would like to say that there is a bug with mine for whatever reason. for some odd reason, i cant start my wifi. i get error when i go into the settings and try to turn it on, i cant change it's settings and when i look at the logs for my (rooted) wifi tether (first time i realized it wasnt working) i have intalled it says;
loading wifi drivers ... failed
activating wifi interface...done
setting ad hoc mode.... failed
setting ssid...failed
setting channel... failed
activating encryption(iwconfig)...done
enabling NAT rules...done
enabling ip forwarding...done
enabling access control...done
tethering now running...done
i might be pointing out the obvious but i do believe the drivers be all up and failin. :-\
SHAMELESS EDIT: I should point out that it was working fine before and i see no reason why it would break so it must be software related. herpaderpa.
Can you please post your exact steps (including errors along the way) so we might have a little more insight?
I think I was using coping over the zip that I downloaded onto my sd card instead of the zip that was bundled in the downloaded file.
I caught it this time while I was writing out the steps I took for you.
Thank you for the help
Does your wifi work? I've yet to hear anyone say they can't connect to a wireless connection yet, so it may be the app. Try clearing cache/data for it too. I'm constantly on my wifi because it saves battery over 3G and have no issues, but I also don't need to tether anymore.. Haven't tried it in awhile.
I found that tethering won't work for me unless I use Barnacle.
I've used barnacle and pdanet in the past, I rather liked pdanet since I could get my desktop on the wireless and not stay in a cold basement.. lol
Has anyone else had tethering and/or wifi issues? I can't support an app obviously because I didn't write them, but we can still help out. :P
Ok i guess i can switch to here.. The phoex zip install keeps aborting.. everything with Odin worked ok.. had no problems with the laptop seeing my phone.. Should i try redownloading the zip and adding it to my sd card again.. or a different rom? any suggestions would be welcomed..
yes, sadly, i cannot turn on my wi-fi at all, and it appears to just kind of idle there and never really turn completely green in the indicator, staying a dull barf failure gray-green; at least when i turn it on from the power management widget. when i actually go into the wireless settings and try to turn it on i end up with this error where it should be showing me the info about the connections status. i will try to attach a picture of this . keep in mind i am actually using my laptops horrorterror web cam rated at an astonishing 0.3MP so it will be awkward and likely your new definition of awful. but it should give you an idea of what i mean.
NON-EDIT-EDIT:meh it could look worse.
REAL-EDIT-EDIT: Thanks Kevson! I restarted the Censorship out of it and it worked! i did before but clearly i need to RESTART HARDER!
I've had that error happen to me when I was trying out different tethering apps. I restarted my phone and it started working fine again
Reactions: knarf802
I'm sorry that you're having issues. Can you post what exactly it shows on your screen when it aborts? For example, "E: status 6" and crap like that.
knarf802: Glad you got it worked out! Sometimes even the simplest things are the best solution :P
Another PhoeniX 0.3 update!
I hope to release within a few days! I now have extra data space working 100% of the time! I do not use the traditional /sd-ext method, I literally mount my partition as /data itself. Why waste time creating symlinks and moving crap back and forth when you can just use it as-is? It doesn't make sense to me. Starting with PhoeniX 0.3, there will be two editions! (technically four, but only because I'm adding Boost Mobile)
  1. Standard
  2. PhoeniX+
What is PhoeniX+ you might ask? This will be the edition that relies on a partitioned sd card and mounts that partition as /data as mentioned above. No more insufficient storage space for the tiny replenish! When 0.3 is posted, I will also be posting how to format your cards. I recommend at least a class 4 sdhc so it can be read from fast enough. I don't know if lower classes work because I only own a class 4.
  1. Standard
  2. PhoeniX+
aye.. sorry still kinda slow with replies.. i sent a PM but i can post in here.. from where i install the zip (phx 0.2) there are no codes or anything.. it just says finding packages, installing packages and then installation aborted. upon a successful installation... will it say complete or done? and an auto reboot? i am not super worried because i do have access to the CWM i think thats what it is.. and i guess i could maybe get a rom somehow.. just would like to make the deal complete with your ROM
Reactions: scorpio42lek
On a successful installation, it will NEVER say installation aborted. I've never seen it not give a reason though. If you haven't already, reboot the phone (in recovery mode, even if you haven't turned it off after it failed please) and try again. If it still says aborted, I need you to pull a file for me. Using adb, do "adb pull /tmp/recovery.log /path/to/save/recovery.log" and post that for me. I'll see exactly what's going on.
well i cant see everything and i cant get it to show up for a screen shot..
from what i can see..
tmp/recovery.log was co
dcard/clockworkmod/recov
lease open ROM Manager t
he issue.
i hope that was the correct file?? :-/
that might have been the wrong file.. that was from the report error.. i cant see other files and it wont show on my pc when i try to get it to mount. i would try the proccess all over but i an not sure if it would be ok.. being that i cant enable the debug.. and from my limited understandings.. the only problem is not being able to install the zip..
jenleasch12683
