[ACS][ROM] Phoenix ROM 0.2 & EXT Data
I get the same issue of being stuck on the splash on.3.
Version .2 works perfectly fine though.
Sent from my HTC Rezound via Tapatalk
MyColorScreen
Re: [ACS][ROM] Phoenix ROM 0.2 & 0.3 RC
I wonder if this is a file-system issue...perhaps the ext4 format script is not working properly. That could cause a freeze at the first splash screen.
Can someone tell me where i can get a list of safe apps/services i can remove from the replenish, Thanks.
Subscribing! Thanks for sharing because I'm sick of this phones storage space issues!
Well crap. I don't have the 0.2 on my SD card anymore, so I can't flash back to that, and the 0.3 RC is stuck on the boot screen. I've tried wiping /data and /cache to no avail. Tried re-flashing the .zip with no success.
So, for the moment, until I can figure out a way to get the 0.2 file on my SD card, I'm pretty much out of luck.
Ok, so maybe I'm doing something wrong?
When you say that the 0.3 RC is just the flashable zip, you mean it can be installed by holding U on boot, and install from zip, right?
I don't think it works, no one has reported success. I'd go back to a backup, 0.2 or get stock from firehak.com
I'm really sorry guys. I'll have to take a much closer look over the weekend when I've got the free time. For those stuck, the 0.2 link is still on the ACS forum and my web site.
To get 0.2 on your SD card, can't you just take it out and put it in a computer?
No worries, Firehak, that's why it's called a candidate, right?
Rodya, yeah, I could just put it in a computer, which I did. At the time that I wrote that post yesterday, though, I was at work, and didn't have a micro-sd reader to work with.
I'm back and running on 0.2 now.
But a candidate I feel really bad for delaying so long :P
Question about 0.3
When I decide to make the jump from 0.2 to 0.3, will I lose all the "stuff" I've downloaded (and the data - photos, docs, etc.) or does it only overwrite like an "update"?
I'm just jazzed Firehak is still working on it. Many thanks to Firehak, dmrlook, shabby penguin, and everyone else allowing us to have a better phone.
I tried to make a TAR using just the boot.img and recovery.img. (Like the .2 release had.) In ODIN, it hangs at "BOOT".
Had anyone reported success on Phoenix 0.3 RC? What is the general consensus? Download or don't download.....????
Thanks in advance!
just keep what you have,he has to work out the lil kinks in his update
Sorry, work has been a bit hectic.. My shifts have been back and forth between 7am-5pm and 4pm-midnight.. When I work nights and then go in again at 7am I pretty much fall asleep as soon as I get home. I did have an idea that if I take the original fa19 installer and remove all lines save for the modem installation, we could then let you install 0.3 RC. I'll try to get it tonight. I promise I haven't forgotten you guys, I've just been way busier than I'm used to!
vickyy
