[ACS][ROM] Phoenix ROM 0.2 & EXT Data
All of that has been done, same as with RazzMaTazz. I am thinking that we are not the only 2 people out there with this going on, however. Maybe someone figured out what was going on....
Well, it would not install all of the drivers successfully on my other Win 7 64 bit machine, but worked just fine on my Win XP machine.
I have Superuser installed, so I guess that I am rooted?
Thanks, guys :)
Adb shell
And it should have # instead of $
Or
Terminal emulator
$su
And it will ask for su perms
Sent from my SPH-M580BST using Tapatalk 2
Yep, good to go :D
I keep getting a "System Update Available" message now. Do I need to do that "Replace all EK18 to FA19 references" thing to get rid of that?
I think that everything (almost) is set up now. Thanks a bunch to all of you on this forum - couldn't have done it without you!
AAAGGGHHH! :mad: I just tried to resize my partitions and now my Replenish won't recognize my SD card or EXT2. Has anybody else run into this and what to do to fix it? I've got the SD backed up, but I couldn't figure out how to back up the EXT2 partition, so if I have to reformat it, I'll lose some of that stuff (I do have it backed up with Titanium Pro).
Any suggestions?
Re: [ACS][ROM] Phoenix ROM 0.2 & 0.3 RC
So, unfortunately after a couple of months of running off the /data partition (I followed your steps), the phone is crashing. It will just suddenly reboot while I am opening texts or running apps.
Do you know what could be going on? If not, how would I direct it to go back to using the internal memory? Thanks SO much. I sure have like having the extra memory.
try this,
Boot cwm
Clear caches (dalvik too)
Fix permissions
Reboot.
Or to go back to internal just delete sd ext partition
Really, I tried taking out my SD Card (essentially the same thing, right?) and my screen just goes black. Is there a way to flash it and tell it to boot from internal memory now? Thanks so much!
How can I upload his Odin (ext-boot.tar) without the SD Card partitioned if I can't even boot without the card partitioned? Thanks so much for your help!
Can anyone help me? I installed the zip file, it said "You're all set" and I rebooted. It won't go past the Samsung SPH M580 screen :( Can anyone help me, please?? I can't get on my phone.
I had a bit of trouble, but I switched the phone back into mass storage mode from the CWM5 boot menu and reloaded everything. It worked! Thanks for working on this. Making a free phone even freer for free... How do I nominate you for sainthood?
Heritagesa01
