Adaptive refresh rate is broken on beta
You might be wondering why your battety life has taken a hit if you're on beta.
Just be aware to that the adaptive refresh rate is stuck at 120 on beta.
I'm not seeing that behavior on my unlocked Note 20 on Verizon. I'm able to go back and forth between 60 and 120 refresh rate, am on the beta.
Yes you can manually switch to 60 but Adaptive is stuck at 120 and not variable as it's supposed to be.
Tried to submit feedback today but got this instead.
Do you use 2 sims ? Put the original back you signed up with , this happened to me , I used att to sign beta then used my Tmobile , once I put back att it was ok
That worked. Will I have to change Sims again when there is an update also? Not hard but annoying, lol.
knightrider85
