Advanced options missing after upgrading note 2
Soli54
3
After upgrading my note 2 with the latest firmware in not getting the advanced option to go to clean delvik Also the touchwiz is gone.
Downloading firmware from Sammobile is almost an impossible task as it takes hours n then gives a message saying download failed. Can anyone please let me know an alternative place to download the latest firmware?
How did you upgrade your device? The only way to specifically wipe the Dalvik cache would be if you had a custom recovery.
Anyway, what model do you have? There are few other sites like rwilco and Samsung updates that still have some stock ROMs.
I updated via mobile odin.
I have note 2.
I have note 2.
Have you checked those sites I mentioned?
If you had a custom recovery and updated via Mobile Odin that would have replaced it with the stock recovery. You can't downgrade back to the old one if that's what you were trying to do.
Sent from my Galaxy S4 running SlimKat 4.4.4
liquidsnake757
