After flashing ROM....Nexus stuck in boot. Need Help Bad
geeforce1
Active member
Jun 5, 2010
42
I need help. I used the Wug's Galaxy Nexus Root Toolkit, to root and unlock. I downloaded rom manager and flashed clockwork mod. After several attempts I even got it to load in recovery mode. I then tried to install "codenamed-droid" ROM and when it restarted it just gets stuck in the 4 color boot animation.
I have pulled the battery 4 times and still nothing...I can't even get to recovery mode to factory reset it. I really need help.
usually bootloops are caused by forgetting (or not wanting) to wipe data/cache
at least that's been my experience.
what did you do to get it going?
It took a moment but I pulled the battery and as soon as I put it in I held the volume buttons and power and got into recovery mood. After that I factory reset and it restarted. I then flashed the rom without rom manager and it all worked.
drakenhu1
