Air Command greyed out after Marshmallow update
Air command no longer works when I take the s pen out. If I go into settings, air command is greyed out and won't let me turn it on. Any suggestions ?
Thanks
Hi I had the same problem with my note 4 .
Solution :
1.Enable Talk back for a few minutes .
2. Disable Talk back.
3. Shutdown
4. Switch on and try to enable air command.
U're a genius.
Ok I had to do that twice but works perfectly.
Tks
Found a solution!
- remove s pen
go to
Accessibility
Dexterity and Interaction
Universal Switch (turn it on then select add switch)
Select Accessories then hover the s pen and click the button.
Works like a charm for me.
try this
go to settings/accessibility /vision /voice assistant /on
used it for few minutes in that setting
than restarted the phone
than put voice assistant to off
voila air command started working
IT ******* WORKS! My Note4 had the same problem, although it wasn't voice assistant but talkback, it works! Thanks, man!
I took out S Pen, then turned on and off the Switch Access and Hover Zoom option on the Vision section of Accessibility settings. Air Command is back now."
after 3 months from trying solve this
'it work perfect with me contact me if any problem and inform me if it work on my facebook thanks all😉😉😉
I hope it's working now... in case it hasn't, i had the same problem... "greyed out Air Command" i tried switching mode from Standard to Easy Mode... pulled my S Pen... air command worked, :D ... switched it back to Standard... Viola... although I'll try restarting my phone just to be sure it stays that way...
Go to settings/ accessibility/dexterity and interactions/air wake and turn 'on'. Go back to S pen settings and greyed out options might now be alive again. Set up as you wish and then go back and turn off air wake
This worked for me! Accessability- switch access on, then Off. Hover to Zoom on, then off. Immediately got Air command back. Note 4.
for my Galaxy Note 4, it works like magic. I lost my air command menu after upgrading marshmallow. I followed below steps:
1. Take out s pen
2. Go to accessibility
3. follow vision
4. Switch Access - On then Off
4. Hover zoom - On then Off
5. Click s pen button keeping it over the screen - - I got my air command menu back.
please let me know if it works for you or not.
Thanks it worked for my Note 4... What a relief :)
Wooowww mr. Genius, you helped my day, brilliant guy, i'm confused for several weeks now, until i had the time to browse google and found this forum with lots of geniusses inside....
Thank you all,
My N910G works perfectly fine right now
andiox
