AllShare Cast Wireless Hub
Certainly should be! Any standard Micracast adapter should also work. I'm using an ActionTec ScreenBeam.
It works great unless you root. There is a fix even for those who root but I'm trying to find the Stock Recovery File so I can flash it using Odin. I thought I had it but it is only 7 megs.
It was the correct file so I am rooted and I still am able to use screen mirroring with my all share cast hub.
ips gaming 88
