- Feb 6, 2017
- 98,417
- 14,712
- 113
I'd love to be able to turn off the battery percentage on AoD since I like to keep my percent indicator turned off.
I think you can achieve this with Good lock app .
Looks like that just works for the lockscreen. Though nice, the AoD still has the battery percent. Though I could just turn it off, I really like AoD.I think you can achieve this with Good lock app .
I guess a workaround would be having AoD display the home button only which effectively gives me a pseudo double tap to wake into the good lock, battery percent- less home screen lol
Yeah I'm using the N960U1 version on Verizon and I don't see a setting anywhere to turn off AoD battery percent. I make it work though with it ONLY being on AoD. I don't get anxiety while I'm actively using the phone since it's off in the status bar. LolI'll check it out see I find that setting for you , thought I seen it before . Get back to you in a few
Yeah I don't think there is one unfortunately. But, having it only on the AoD is alright.I haven't found a option to turn off battery percentage on AOD
