Am I correct there is no bluetooth keyboard for Verizon tab?
The Sprint SGT still lacks the BT HID profiles required to connect to a keyboard. It pairs, but will not connect. It would be nice if someone developed the BT stack for it.
I picked up the xoom keyboard at the verizon store today. The salesgirl tried to tell me tech support said that it wouldn't work with the galaxy tab, but I bought it anyway. After a little trial and error, I got it up and running. At first, the pin dialog for pairing would come up and disappear before I could enter the pin. I finally tried holding v, a, and r while turning on the keyboard (this is the pc connect method) and it kept the dialog open while I entered the pin. Anyway, it's up and running and works great except for a couple of functions. The back and home keys work fine, but the menu and apps keys do not. The music player shortcut doesn't work, nor do the music controls. They may work with other music apps, but I didn't try that. All of the other android shortcuts work fine. All of the standard keyboard keys work with the exception of the caps lock, although I only tried it in memo.
wmorg
