Andriod Q Beta Starting
Ok ...good
Thanks
That is correct. Mustang7757, I remember someone posting a cropped screenshot of a Google employees calendar that notated "Android Q Beta 1" Wednesday March 13th. I believe the others in the past also got released on Wednesday. Take this all with a grain of salt but hopefully proves to be true.
Thank you , hopefully tomorrow
If you are a beta tester for the Google app, are you automatically included in the Q testing?
Is there a link to sign up for beta testing Q?
You can't sign up for Developer Preview. You can sign up for the Public Beta release closer to when it's ready to roll out. Keep in mind if you install Beta and want to roll back to Pie it will wipe your phone. If you stay on Beta, once it is over it will upgrade to the Q release.
Thanks for the information, Mike. I will keep an eye out for the Beta release.
True ..
How does one download the Developer Preview? Also is it a good idea to run a DP on a daily driver? I have always been one to run Beta versions and have had good luck.
Once it's released you can Sideload it. I don't recommend it because it will break things like Google pay. The public Beta is much more stable but even that can have issues.
rido7788
