Android 10 update
Seems like plenty are having issues with it
None so far. Runs great.
I'm still using Nova Launcher, though. I tried the One UI gestures and literally cannot get them to work if I choose the option for using gestures from the side...so I re-enabled Nova as the default.
I'm liking the clearer text, better notifications, dark theme and other cosmetic changes, though.
No issues so far that I am aware of yet (but it's only been a few hours). I wish Hangouts had a dark theme/mode but it's nice to finally have a dark Gmail. Also nice to have secuirt updates through February now (even though March was just released...)
Gonna try to see if I can get edge lighting working properly following the update. Never worked correctly for me before.
It kills the ability to send/reply to texts on Android Auto. It also is causing some people to have issues with voice recognition of OK Google while connected to Android Auto.
Two things I literally never use. The first I don't ever use, on or off Android Auto...the second, well, I don't text while driving so I have no need for such a thing.
I also had the texting issue. I solved it by installing google messages. It seems to be the stock samsung texting that it has the issue with.
Glad that worked for you.... I tried Google Messages, Pulse, Textra, Samsung Messages, and Verizon messages. None of them fix the issue of Google saying "Sorry, but this internet connection isn't strong enough at the moment" when trying to send a text or reply to a text when connected to a car's head unit via Android Auto. It's a known issue that is specific to Android 10, not an app issue. Google has acknowledged it and "is working on a fix" since Feb 6th. Sooooo, we might see a fix by August if it's like any of the other "urgent" issues that Google has addressed in the past.
Clearing the caches on Google and AA and deleting your car(s) will get you one message or a few minutes of messages. But then it is back to not able to send.
Regardless of whether you use it, the function is broken. Someone asked what was broken, I responded. Glad you don't need those functions. Many of us do.
One thing I noticed is since the update my battery doesn't even last me 4 hours even when not using my phone
I got the update that took about 30-45 minutes to complete with a reboot. There are lots of changes!!!
Looks like TMo just released the March security update. It just d/l'd to my phone.
Verizon did as well. Android Auto and Google Assistant (when connected to Android Auto) still broken.
Thought I saw somewhere there was supposed to be an update that fixes Android auto
dumpsterrentals104
