Android 11 update
Tried it a few times. Always wound up deleting it.
I wonder why they think it's better to scroll through multiple pages of apps that used to fit on one or two.
Not sure it was like that through beta
I see. Not my preference, but not going to lose sleep over it. Thanks for your help.
Your welcome! By the way it's only one module to use in good lock called home up , let's you adjust home screen grids and folders, don't have to use anything else .
My Calendar icon of Samsung Calendar no longer shows current date after Android 11 update. Always says 28th
Edit: Nevermind. Was a Theme problem.
Something went wrong with the update on my note 10+ on Verizon. After it restarted, the pin pad was the same color as the background, and they numbers were almost unreadable. I was able to enter my pin, but it did not work. I was unable to power it off using the power, and down volume key, only restart. I was not able to get it into recovery mode either. I eventually entered my pin number enough times, it wiped the phone. I was able to get the phone working again, but I was unable to restore the phone from a google backup. It told me my screen pin was wrong. I was able to restore some elements manually such as contacts and calendar entries though. Any ideas what could have caused this?
This was OTA download?
Very strange , it's possible they can get corrupt , was there any interruptions during the download?
There were no interruptions that I know of, it had downloaded overnight. I started the install yesterday morning, and let it go unattended. When I came back to the phone, I got the results that I mentioned in my original post.
My phone is running normally now with Android 11. I guess it was just a glitch that the cause will likely never be known.
Yeah something must of happen:(
I always watch the updates just in case
Just installed it for AT&T. I like how One UI finally fixed their tiny font problem. I never used it because widgets displayed a font size that was too small and you couldn't change it. When I get my S21 Ultra next week I'll probably use it instead of Nova.
Great, I'll get my wife's Note 10 plus update tonight. Thanks for the info.
Burwil, are you saying there is a control for text font size in widgets? All of my Samsung widgets have smaller text size now. The only way I see to adjust it is with Screen Zoom. But that increases size on everything.
That's odd and different from my experience. My One UI version is 3.0. and in previous versions the fonts for almost all my widgets were too small. Now they are normal. I don't see an adjustment setting.
It does appear we have different experiences related to ONE UI versions. Can you tell me what your Screen Zoom setting is? Is it all the way down?
Screen zoom is 0. Here's a screenshot of one of my screens with widgets......
Ok. That's a 3rd party widget. My small text 'issue' is on the Samsung widgets. My Health widget looks the same as yours. Guess it will be better when I get my new glasses next week. Anyways, thanks for checking.
williestringfield90
