Android 12 beta now available.
Status
Not open for further replies.
Here is how to do it. Make sure you have the android beta button in your quick settings. If it isn’t there click on the edit pencil and add it.
When you click that you can click the send feedback button.
Thanks so much Kizzy, really appreciate your help
I'm just wondering if everyone is having the same issues I am using bubbles for messaging? Between the text box often being hidden by the keyboard, and the expanded bubble sometimes not being full screen, and even the magnifying area sometimes sticking, I seem to see lots of bugs. Thinking about turning bubbling off until the 2nd beta is released. We should get updates about twice a month, right? I should say this occurs in Google Messages with Gboard. Don't seem to see the issue in FB Messenger.
Following up on the problem with messages, I've lost the gif and favorites portions of the Selections in messages. I have uninstalled and reinstalled it did not make a difference so it may be a bug
If you tap on the emoji icon in the text box, they come up as tabs, along with emojis. Does that work for you? I think that was a recent server update in Messages..
Another bug. No sound notifications from apps that I've chosen to sound notifications with Do Not Disturb on. Sent a bug report.
See my last message
You know, I was just thinking, in addition to running the Android 12 beta, I also run betas for Google and Gboard. Do any of you ever leave those betas to see if any of these bugs can be resolved? I'm assuming if I send bug reports, they'll see the versions I'm running of those apps.
Never thought of that. I will try that and see if it helps with my bubble issues.
Thanks! Just realized that I also have a beta of Messages running as well. I will update Gboard using the link you posted, if still not resolved, I may leave the Messages beta.
I may do. But I still had the disappearing bubbles when my husband sent a signal message just now. Didn't even get the chance to reply.
I'm on the beta versions of Gboard and Message. I haven't observed any issues connected to those apps that I know of.
The Bubbles for Message and Telegram seems to work differently than before the beta but I can reply within the Bubble. I kind of like that. I need to play with that more.
Text box still covered up by the keyboard. I'll continue testing prior to leaving the Messages beta. I don't think it's quite as bad as it was before, it's not totally covered.
Status
gocoronago2021
