Android 12 Official Release ..5 bugs and fixes.
  • Thread starter Thread starter Deleted member 2609113
  • Start date Start date
I have a pixel 3xl, my boy has a 4 5g.
he does not have the issue, but I do. whatever color theme I pick, tints my screen while taking photos or video.
At a hockey game today, while on blue theme, the ice had a blue tint, switched to orange/yellow and the pictures showed the ice with a yellow tint, same when I changed to brown
This update is horrific! I have a $1200 almost brick. Many apps crash and don't work at all. And some are super important to me, like Square. I tried all the "fixes". Nothing works. So ticked off right now .. .
Only thing I haven't done is a factory reset. But I don't think that will help anything, either.
What phone and how did you download it and install?
I'm having issues with notifications being silenced, and the call screen not appearing when calls are coming. Also, Gear S plug in keeps crashing. I'm on S21 Ultra unlocked from Samsung directly. Anyone have any suggestions? I've tried resetting the phone multiple times (before and after changing the notification settings), but to no avail.
What do you have with Gear S pluggin?
Maybe thats where your issue is with notification on phone
Thought about that. Deleted the entire Galaxy Wearables app with the plug in. Restarted the phone. Still the same. In the last hour, though, some of the texts are coming in like before. Any other thoughts? I really don't want to do a factory reset.
Give it another day or 2 see if it fixes itself since some are coming back to normal.
Thinking back, the issue seemed to start after I silenced one of the conversations.
If you silence them through notifications panel you would need to go to settings>notifications>recently sent>more and check each app notifications on ?Screenshot_20211201-014835_Settings.jpg
If you silence them through notifications panel you would need to go to settings>notifications>recently sent>more and check each app notifications on ?View attachment 339438
No, I silenced the convo directly from the Samsung Messages app. But I did follow your advice and go to notifications and tried to toggle between detailed and simple notifications to see if it would make any difference. I also tried to change the messaging app to Google Messages thinking the actual messaging app was the problem, but the issue didn't go away. I went switched back to Samsung Messages as my default, and I think you may be right. Maybe it needs a couple of days to "settle in."
See in couple days then
One bug common between my Pixel 4a and my 6Pro is "Do Not Disturb" will turn on without me activating it. Now I do run a couple of routines that will turn it off with success. Then later I will notice DND has been turned on. I'll turn it off and it will not come back on until I run a routine to do so.
I've seen a few other people complaining about the same thing. Not that big of a deal except I might miss a phone call or two until I turn it off. It's a small bug but one I hope gets fixed in the future.
CorpusChristi367
