Android 12 Official Release ..5 bugs and fixes.
  • Thread starter Thread starter Deleted member 2609113
  • Start date Start date
Never had a problem with DND starting as programmed ; however, can't speak for ending as programmed. End Time is set for 3AM and cannot remember the last time I woke up after 2:30AM and first thing I do after letting the dogs out is turn the DND Off. Maybe I'll change End Time to 2AM and see if it works as programmed. (Just did that, End Time is set for 2AM...I'll check tomorrow.)
I have never been able to get that feature to work. I've come to the conclusion that it's for pGoogle Home, to be programmed from the phone but not FOR the phone. Maybe not but that's what it seems to me.
I have DND set to end every morning at 5AM and it ends as scheduled on its own 99.9 % of the time for me
Are you able to send us a screenshot of your settings?
Here you go. I just noticed the Alarm Ends.... option. My alarm usually goes off at 05:15 so I will need to verify my statement above that DND ends by itself and not by the alarm. I totally forgot that option.
S21 Ultra. It upgraded automatically.
This is strange. The first beta made my s21ultra unpleasant to use. Choppiness and app crashes. The final beta fixed it, and the official release thankfully didn't mess anything up. Many people are experiencing just the opposite.
It worked. Got up at 1:30AM, did not touch the phone till after a cup of coffee and just checked about five minutes ago, and it was turned Off. Took a screenshot....
Here's the settings page.
Thanks for the screenshot. Now I realize we are discussing two different scheduling features.
My post is referring to the "Daylong" routine scheduling in Assistant. See screenshot.
I have three routines related to work, clock in, lunch and clock out. Each one has Do Not Disturb and turn on Bluetooth involved. Lunch routine should also set alarm for 11:55 am. I haven't had any success in getting those to run.
Any bug fix updates? Tumblr, Facebook, are a few of the many apps that just crash when I open them up.
This OS upgrade has messed up a lot. Wear keeps crashing. Connectivity issues.
smith-jhone
